gmarshall43
- May 5, 2002
- 201
Any Elgin fans out there? I recently picked up an older Elgin with this number stamped on it, 401-41041. I believe it to be late 40's and about 3hp? I want to remove the mid section and lower end from the power head. I removed about 8 screws below the power head but it doesn't drop off. I've tried to pry gently and didn't use much force not knowing if something was holding that lower end on but it didn't budge. How does that come off? I've also tried to drop the lower end off and there was only the one bolt holding that on but it too didn't budge.Any suggestions?
Thanks,
Gary
Thanks,
Gary
