They were as good as any in their day. As previously noted, if you have the patience and desire, you can make it work. Starting with a basically healthy motor that needs basic tune-up stuff is a plus. Consumables like carb parts, water pump impellers, ignition bits, can be found if you look. Rebuild parts, ie. pistons, rings, etc. might be a bit harder to come by...
