I have a 69 Sears boat with a 75hp McCulloch engine. I had it running a while back, but that was after replacing the 14 amp inline fuse and jumping the solenoid. Thought I had a bad ignition switch, so I replaced that. Then I replaced the starter solenoid. I have a short somewhere and have noticed two wires that aren't connected at all in the main harness. One light blue wire looks to come from the coil, but the PO cut it midways back. Another is medium sized white wire that's cut. Haven't traced it yet.
I'm hoping that someone has a wiring diagram for one of these boats out there? Right now, all it is doing is blowing that 14 amp fuse. As soon as I put one in, it sparks (while I am connecting the fuse holder!).
