Ted Williams 7.5
rthitoff
I have a Ted Williams 7.5 that's like brand new. I know it's air cooled but I'm thinking that it has water cooled exhaust. Is this correct and should there be water coming out of the two small exaust holes above the water line?
rthitoff
I should have water coming out of the two holes? Is it only when it's in gear? What pumps the water? Where the heck do I find info on this engine?
brim_buster
I have the manual for it. Send me your email address in a private message and I will send you a copy!! There should be a mist of water coming out the holes and its has an impellor in the leg that moves the water up a tube. Make sure you have enough water to be above the cavitation plate. About 4 inches above it.
