marksa1458
- Apr 6, 2009
- 93
I have been working on restoring a 1975 Century Arabian. Finally, I am getting around to the motor which is a Chrysler 440 RH Rotation. The motor puts out 330 horsepower and is connected to a Paragon Gears PV41-R transmission. The condition of the motor is a mystery as I have no idea if it was properly winterized before it sat for a few years (I am assuming the worst) The motor does turnover, oil is used but doesn't have water in it. At minimum it needs a new starter, alternator and a carb rebuild.
In talking with my local rebuild folks, rebuilding this engine may not be the best way to go because replacement cam shafts are no longer available. I would hate to sink 4 to 5K rebuilding this engine, have the cam fail and be out that money.
What is the best way to move forward as 16K for a new motor/transmission/vdrive is way out of the budget.
- Does it make sense to rebuild what I have and keep and eye on eBay for a replacement cam if I should ever need it?
- Would it be better to find another engine of the same horsepower? What would be the most optimal engine to go after and what would I need to change to mate it to the existing transmission.
- Should I just look for a complete drivetrain out of another boat to use?
Thanks in advance for your thoughts!
