yamaha 4.3 sterndrive
Status
Not open for further replies.
K.A.P
overheating after running on muffs for 5-10 min.
Water is circulating.
I put a new thermostat in and instead of the temperature rising all the way to 200 degrees it now stops for a couple min at 140 then just creeps up every min with no signs of stopping.
took intake manifold off and it looks like I am backtracking someone else because the gaskets and water inlet holes are cleaner than I expected. Oil is clean in there as well.
checked the impeller and again looks like previous owner beat me to it.
One riser was a lot hotter than the other one so I disassemble that and noticed this crack in the exhaust manifold.
could this be the problem? I know it needs to be replaced but does it sound like there's more to it?
GA_Boater
Did you find the solution? What was wrong?
Please read the Help Tip on top of the page and start a new topic explaining your problem. It's very hard to get a member to respond when they haven't been here for a year.
Status
