2009 PMC 5.7 L with "PMC Fuel Control Center" (FCC) with low and high pressure pumps with a return system.
Motor M# 50-570-06, Ser# 690034
I have changed all fuel filter/seperators (including the internal one in the FCC), plugs, wires, Distributer cap.
Problem occurring after de-winterizing this weekend. It will only idle and the idle is rough. If I ease gas into the throttle body with a Dixie cup it will smooth out. I have also tried an external tank with no difference. Opening the throttle causes it to stall. If I jerk the throttle fast I can get the RPMs up but the engine is backfiring.
I have not checked fuel pressure, but the problem is bothering so I decided to post. Still unsure at this point if it is an electrical or fuel issue.
