Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
pcm 4140 on a 17 ft sunliner
  • pcm 4140 on a 17 ft sunliner
    I bought this boat to keep out at my lake house, and the upon recieving the boat I cleaned the carb, changed plugs and coil, changed the oil and cleaned all of the connections. Ran it a couple days and everything was fine, the temp was at 170-180. And oil press was fine. Then I was pulling a tube and the motor all of a sudden cut off. Just died down like I ran out of gas. I still had half a tank and the engine was getting gas. But the boat was now reading 220 degrees. So I let it cool down.to 150 and tried starting it and it wouldn't start it just backfired with a lot of white smoke. Checked my coolant tank it was bone dry. And in my gas filter had a little water. I emptied my gas tank. Now for the engine what procedures should I do to find the problem, also can I even buy parts such as gaskets for this motor.
    Re: pcm 4140 on a 17 ft sunliner
    Ayuh,.... What IS a pcm 4140,..??..??
    • #3
      Pleasure craft marine and it has a Mitsubishi 4140 I can't find much on these
      • #4
        Ayuh,.... Never seen a Mit gas motor in a boat... heard of some diesels...
        I'm somewhat familiar with pleasue craft... in that they marinize motors...
        • #5
          Hello Phil,
          I have the same set up on the same boat (mine is the inboard version). There are quite a few of those motors around, and you should have little problem finding most parts. The PCM 4140 the the marine version of the mighty max truck, and most part will fit. The marine related parts can be found at www.skidim.com, I was able to locate most I was looking for there.
          I have also relied heavily on the advice of members of Fish the Classic, a shamrock forum, since the shamrock 17 has the same engine.
          A problem common to most of those engine was the corrosion of the ex. manifold, especially near #4cyl. with time, the damage would extend to the cyl head. I replaced mine a while back.
          Good luck, I have just started working on my boat after several months, if you need anything drop me a line!
          Back to Top
