I have a 455 olds Hardin that seems to not have a Dipstick. I cannot find it anywhere. I have it at a marine mechanic now and he said some of the 455's were made without a Dipstick. Is this true? How do I check the oil level if this is true?
There is a oil drain kit connected to the bottom of then block. A black rubber tube that I can unscrew and change the oil. One drained and refilled, could I check the oil through the tube where I add the oil to the engine? The diagram was helpful, thank you. But i don't see a way to check the amount of oil other than where I can add it?
