1992 yamaha L4 3.o
ricovw
Re: 1992 yamaha L4 3.o
which parts, and which pump?
there is a raw water pump and a circulation pump.
dunkle66
i asume the circulation pump. the one that cools the motor. it runs off a belt that is driven off the crank pully. i dont need the whole pump just the guts of it.
Don S
They both do. Are you replacing an impeller because you heard that it's "the thing to do"?
dunkle66
no. i need it replaced because the boat overheated and i tore the pump apart after i got back to the dock and found that all the blades were gone from the impeller
Just got a bunch of parts for the same setup including the impeller & o-ring at boats.net. For the stuff we needed they had the best prices.
ricovw
That's the raw water pump. I just used the jabsco impeller equivalent. I dont have the number handy, but if you need it, i can provide it tomorrow. Let me know.
dunkle66
the part number would help me alot. thank you.
ricovw - I'd like to know that part number as well. Tired of paying Weimar Republic prices for the OEM stuff.
Thanks!
ricovw
Okay guys, here it is.
The Impellar I use is made by Jabsco, and the part number is 1210-0001. That is the number right on the impellar. Shouldn't be very expensive at all.
Rico
