Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Help Identifying Holley Carburetor
  • Help Identifying Holley Carburetor
    Hi. I have what I believe is a 1979 Pleasurecraft Waukesha 302, Clinton Iowa, with a Holley marine 4-barrel carburetor. The MotorCraft tag on the carburetor reads EOJL CA A 1F17. Holley told me they cannot reference MotorCraft numbers. Can anyone tell me the Holley model so I can order the correct rebuild kit?
    Thank you,
    J
    Can you post a pic?
    http://www.carburetion.com/CarbID/FordID.htm
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 SeaDoo GTX
    Raw Water Pump Maintenance
    Merc Adults Only
    G-Dad always said "First Liar doesn't stand a chance"
    • #3
      You are sure it's a Holley? Ford did make a carb that at a quick glance was often mistaken for a Holley, though I doubt any of those were USCG certified. As AllDodge said, post a pic.
      • #4
        Look for a list number stamped into the choke horn. If it has one it is probably a Holley number. I am not aware that a Motocraft Holley was ever made in a marine configuration.
        • #5
          Thank you. I think I am in good shape moving forward. I flat out pulled the carb and took it home. There are numbers on the choke chimney. And, thank you for the head's up with correctcraftfan.com.
          Thank you,
          J
          • #6
            Looks like you learned us something today. Holley did make carbs for Ford
            http://www.ebay.com/itm/FORD-HOLLEY-...ZZpaL0&vxp=mtr
            So you need a Kit for EOJL-9510-CA which is a 600 CFM
            07 SeaDoo GTX
            Merc Adults Only
            • #7
              Originally posted by AllDodge View Post
              ......... Holley did make carbs for Ford......
              I knew they did, AD, just was not aware that they made them in the marine config. Interesting that the carb in the link you posted is undoubtedly a marine carb by virtue of its "J" float bowl vent tubes. However it is odd that there is no evidence of it having the gold, di-chromate finish which was intended to retard corrosion that could be inherent in a marine environment..
              • #8
                Carb Number Carb Model Number CFM Renew Kit Trick Kit Needle & Seat Primary Main Jet Secondary Main Jet or plate Primary Metering Block Secondary Metering Block Power Valve Pump Nozzle Size, Primary Secondary Nozzle Size or Spring Color
                R9392 4160 600 703-33 N/A 6-511 122-66 N/S N/S N/S 125-25 0.025 PURPLE
                Primary Bowl Gasket Primary Metering Block Gasket Secondary Bowl Gasket Secondary Metering Block Gasket Secondary Metering Plate Gasket Primary Fuel Bowl Secondary Fuel Bowl Throttle Body & Shaft Assembly Venturii Diameter Primary Venturii Diameter Secondary Throttle Bore Diameter Primary Throttle Bore Diameter Secondary
                N/A N/A N/A N/A 108-13-2 N/S N/S N/S 1-1/4 1-5/16 1-9/16 1-9/16
                Right from the Holley website,
