Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone elses topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when its posted at the end of someone elses topic. And those answers will be specific to your particular issue.
See more
See less
Ford 302 ,Grounding Issue ?
  • Ford 302 ,Grounding Issue ?
    Question was posed to me and I am 1500 miles away. Guy has a 2002 Ford 302 straight inboard and will not start /turn over/trips circuit breaker when in water. Pulls boat out of water and it turns over and fires up right away at the ramp. Has brand new battery and voltage meter shows 14 when underway.Will also start in water when jumped. Couldn't get much info from him other than he bought it like that and PO "knows nothing". Any ideas ? Not sure if a pocket scanner will work on his PCM unless connections are the same as OBD 2.
    Cool Runnings,,, Mr.88
    Ayuh,.... Sounds more like corroded connections, at the battery or elsewhere,....
