I have a 351 with paragon transmission. It started stalling in reverse but did ok with a little throttle. Today it stopped going in reverse completely. Happened when docking. Luckily it's just me at the boathouse so no audience as I got sideways in the slip. I reved it up to 2k in a desperate attempt to not ram the dock, but it still kept stalling. I looked at the fluid and it's full and not burnt or anything.
And ideas?
The bell housings paint is flaking off like it's been hot.
Edit: I was able to get it in reverse if I gunned it at the same time I threw it into reverse. But it wouldn't idle down, if I pulled the throttle back it would die. I confirmed I could turn the prop shaft in both directions when in neutral. Also, usually at idle in neutral the prop shaft will turn a little, now it doesn't do that at all.
And ideas?
