castrolina
- Nov 2, 2016
- 17
Hi there, the upper unit gears on my 1990 Yamaha sterndrive v8 5.0 have been destroyed, I believe due to improper shimming. The part numbers are:
Gear 1 6t5-45881-00-00 798$
Gear 2 6t5- 4588-00-00 864$
My question is are there after market gears that will fit this application that are not as expensive? I took the boat in for shifting issues to a local mechanic and ever since then, the outdrive has never been the same. The shifting issues were still there, eventually I bought the shop manual and figured out the shift fork problem with help from iboats. The bearing housing cover that connects the drive shaft to the upper unit was also cracked and appears it was not installed all the way. If I do decide to get this repaired, can I find or use shimming tools needed at auto parts store or marine dealer? Any help is appreciated, thank you.
