andrewcoon
- Aug 21, 2011
- 130
i recently purchased a 1986 ski centurion with a 351w direct drive. I took it out for the first run and there was a pretty bad vibration. i have searched and searched and have not found a good answer. i know that it could be the prop shaft. But what are some tests I could do on the water to see if i can narrow down the problem?
Next question is when i went out with 2 passengers the boat would porpoise at higher speeds. however when i was alone it did not porpoise. not sure what would cause this. thanks in advance.
