1987 crusader 270 with Quadrajet Carbs. Carbs professionally rebuilt just over a year ago and until about 2 months ago operated great.
This happens periodically and I can't seem to find a common cause.
After sitting for about 12-24 hours no fuel is getting into the carb. Removing the flame arrestor, pumping the accelerator there is no fuel.
If I tap on the inlet or surrounding area it will start and run just fine. (Electric fuel pump works fine, actually new and tested at the carb with correct pressure)
Once running it runs great, no problem. This only happens after it sits.
Any thoughts would be appreciated.
