Hi all, I have a 2.3 OMC in an 87 Sea Ray Seville. The boat hadn't been running for a coupl years. I unplugged the ESA switches rebuilt the carb and it ran fantastic.
Took it out for a full throttle run and it ran great for about 20 sec and then it wanted to die. I had to feather the throttle - like pumping the throttle to keep giving gas to the carb - it reacted like it was starved. I got it back to th dock, adjusted th idle mixture screws to about 1.75 - 2 turns out and took it back out.
It died pretty quick at a lower rpm and didn't want to run at idle. I rowed it in and it started and ran pretty good next day in th driveway.
I'm going to rebuild the fuel pump this weekend, but any thoughts or suggestions would be appreciated.
There is fresh gas, new points gapped to .018, plugs were changed, new coil...just frustrated I wanna be on the water, ha
I'm considering a distributor conversion to an electronic insert under the cap - it's a Mallory. Has anyone done this with good results? And are there any other considerations if I go that route? I think Ive read that some conversions may not be compatible with the ESA switches
Thanks!!
Thanks!!
