74 Fantasy
- Jul 15, 2005
- 6
I really could use some expert advice and words of wisdom if anyone can help. We have a 1974 Fantasy tri-hull with a straight chevy 6, 165 OMC which we have owned for 38 years and are taking a long shot at replacing the exhaust manifold. The last time we used it we notice water in the oil and we drained it out and put clean oil in did not use it anymore. It has been suggested that before undertaking the head maybe it is the manifold since it has never been changed. The boat is only used in fresh water and we have always tried to take care of it. We really can?t get another boat, so we just keep working with the one we have. I know it sounds ridiculous hanging on to it, but another summer?s use would be great and we are kind of attached to it.
I would like to know the best way to go about removing the 4 ?V screws? and nuts on the 2 studs undone and reducing the chances of breaking them. Thus far I have my doubts if it can be done after 40 years and the boat is a very long way from any kind of parts store or boat shop. If there are some specific tools that might help if and when disaster happens while trying to remove them we would like to pack them along. We want to avoid welding broken off bolts to get them out, since that isn?t possible, otherwise it?s a couple hundred miles on the road. From what I have come across easy outs sound pretty risky also, especially if you break them off.
Also I would like to know about sealant on the gaskets, yes or no and the best thing to use. Manifold to head, both end caps and manifold to elbow since we will be replacing these parts.
I added a couple of photos. We have not started taking it apart yet but know it is going to look pretty bad inside after 40 years.
Any words of experience would be very much appreciated.
Thanks,
Robin
Thanks,
Robin
