pantaloonz
- Nov 28, 2014
- 237
Good day!
Quick history: Bought the boat last fall after it had been on the water that previous summer (early summer) but still it was running.
New to boats so I didn't want to take any chances, especially when I brought it home, lowered the trim and water came out . It had not even been close to dropping below freezing so there was no chance at all of water/freeze problems.
I took the boat to a marina for winterization: They did normal procedures, the tank is not metal so it was completely drained, lower unit normal stuff, checked gimbal, new filters all that typical stuff. Marina noted dead battery so I knew I'd have to replace that at first start.
Fast forward to last weekend (boat sat covered all winter)
I added 5 gallons of new fuel
--probably not a good idea but I tried charging the old battery first, and supply 50 amps "start" setting just to see if the engine would kick over. No luck there, even with the 50amps boosting the engine was sluggish at best, no where near enough to supply a good start.
Installed the replacement battery. Much stronger ignition, but not a single turn over. Figured needed time to prime the entire system.. added a squirt of starter fluid in the neck to confirm suspicion and it would "pop" but not keep going.
Called Marina; old gruff technician: "we started your boat during winterization, but we drained the fuel so crank that sucker for a couple minutes and keep pumping it.."
I followed those instructions. -- granted I did not turn the key for two continuous minutes... (that would ruin the battery right?).. but I tried starting it, pumping the throttle, 10-20 seconds of turning it over at a time.. nothing. Did this for about 10 minutes.
I had oil pressure, but it's a mechanical fuel pump.. so I don't know how I'd hear the damn thing even if it was working?
So I pulled up the boards covering the tank. I traced the line from the anti-syphon value to the water/fuel separator and into the fuel pump. I disconnected the fuel line at this connection point (carburetor inlet). It was bone dry and didn't even smell like gas.
*to my dumb mechanical mind I can only thing of a couple things; either the pump cannot pull the fuel, or the pump is bad..
*I didn't check the fuel filter, it was replaced at winterization, and it appears no fuel is passing the water/fuel separator anyway...
*checked the anti-syphon valve; working normally, no screen on the bottom of the fuel uptake and the tube was clear.
I suspect a failed fuel pump, but of course want to rule other electrical issues out as the replacement of this part scares me (even if I could find it)
Some suspect electric issues:
-- blower will not turn on.. -- this appears to be on purpose the p.o. seems to have borrowed the electric plug for the bilge pump and left the blower unplugged.
-- Trim gauge constantly reads UP (though the trim works great)
-- Fuel gauge reads empty (approximately 8 gallons in there now)
-- The two circuit breakers are not flush.. but I don't know if these means they are tripped or not? I can't push them back in anyway?
Not a pic from my engine but they are in this exact position slightly out.. I think this is normal.
-- just reading my own post.. no I haven't checked the water/fuel separator device as I don't know how that thing comes off (yet).. but can that device completely stop the fuel flow?.. do they tend to go bad over a season?
ANY suggestions are well appreciated!
-- I completed renovated the entire interior of this boat.. I'm so frustrated that I can't get it to turn over
-Pantz
-Pantz
