I believe this is a 2gc carb.
It is on an 88 bayliner 140hp 3.0l engine.
Could anyone tell me the proper jet size and float adjustments for this carb.
The mfg number is in the title.
Thanks in advance.
The issue I'm trying to fix is that you have to give it throttle extremely slow.
If you move the throttle too fast it backfires and shuts off.
Furthermore, the boat accelerates for the first half of the throttle throw but the second half of the throttle movement does not accelerate the boat or cause the engine to change in any way i.e. does not rev out
