ruggles
- Jul 30, 2008
- 110
Hi just put in the new shift cable on my 1991 4.3L OMC cobra. i had to make the adjustment tools due to time constraints but they worked well. I did the engine side first on the tool and then aligned the bell crank at 90 degrees with the aluminum bell crank tool I made. was this the correct way? I had the remote shift cable off when I did this but not the throttle cable to the carb. Is this a problem? Should I disconnect the throttle cable and do it again? Also in layman's terms can someone explain how to get the slack out of system? The 5 step adjustments? I read midnight wolfs website but for some reason I am not getting it. I just want to make sure I put it together right the first time. the plan is the put the leg on this afternoon and test her out so if anyone can help me I'd really appreciate it. I am mechanically inclined but boats are a new thing for me.
Thanks in advance!
Thanks in advance!
