Hi guys! I've got a rough/surging idle question. The engine is a 3.0 liter GM, with a 2bbl.Holley carb. I bought the boat from a dealer, where it had been sitting for several years. After replacing all the filters, spark plugs, distributor cap, rotor, and wires, I still have a "surging idle". Especially after it reaches operating temperature. I noticed some "varnish" build-up, coming from the float adjustment on the top of the fuel bowl. If the problem was water/bad gas in the fuel tank, what corrective actions should be done? What cleaning solution should be used to clean the 'gum' from the carb?
Ayuh,... Welcome Aboard,..... How much, 'n what sorta crap did ya find in the fuel filters,..??
Disconnect the boat's tank, from the fuel pump inlet, 'n run off a remote tank for testin' purposes,...
It would also be a Great idea to add a canister type fuel filter, just before the fuel pump, for continued clean fuel,....
While ya got that hose off, suck some gas outa the tank, 'n inspect it,....
If it Smells like gas, it oughta still burn,... If it Stinks, it's junk,...
Pump out the tank, or remove the tank, 'n clean it out,....
Sounds like yer carb needs a Rebuild,...
To do it Right, ya need the rebuild kit, a carb dippin' cleaner, 'n compressed air,....
