ImHoppy
- Dec 28, 2014
- 18
I have a 1990 Seaswirl Sable Cuddy with a 5.8L Cobra that I just recently bought. I was going to change the impeller and do other maintenance so I would know that everything was fresh before I get her out on the River. After I removed the cover over the water pump housing I saw the back end of the housing was melted and a piece of the plastic had actually separated from the rest of the housing. I removed the housing and needless to say the impeller was shot and little pieces of it were laying in the housing. I went ahead and cleaned everything out the best I could and replaced the impeller kit and housing. I've read that I should let it set 24 hours before starting so the gasket sealer can setup or something to that effect. I've attached some pictures to make sure that there isn't something else I should check or do before firing her up. Where does the water discharge from on the outdrive? I looked in the manual but can't find it. I want to know where to look to make sure it is pumping water before I let it run. I do have muffs and good water pressure and I know not to rev the engine or put it in gear with the muffs on...I just don't know where the water should discharge from. lol. Oh, the yellow looking stuff in the pictures is actually tan mud. My flash made it look yellow.
Thanks,
Hoppy
Thanks,
Hoppy
