Have a 1989 Four Winns 210 Horizon w/ 5.7L King Cobra outdrive. Have owned the boat for the past 3 season and it seems to be about the same since I owned it, so not sure what is normal. I just changed the Bellows & Gimbal Bearing. While researching I found the hasting's info about critical cable adjustment or plan on eating gears.
The shifter is hard to initially engage, (forward or reverse) but very easy after it passes the 11 or 1 o'clock position. Have removed all the cables from the remote control. It takes 2 lbs (on a spring scale) to move the shifter from full forward toward neutral, but 10 lbs to move from 11:00 - 12:00 o'clock position. Same on reverse - 2 lbs to move from full reverse to 1:00 o'clock, then 10 pounds to move it to neutral. It seems to stick. Is this normal? When I pull the shifter out to run just the throttle, it moves the entire range easily at 2 lbs. Can the shifter be repaired or must it be replaced?
I have tested the disconnected cables. All 3 cables (Shift, Throttle & Transom) take 4.5 lbs to pull them. According to the manual, everything should run 2.5 lbs, when connected. Time to replace? or adjusted? Just want to verify with someone that has experience with the cobras before I shell out hundreds $$
Thanks in advance for the feedback!
