Gerard1970
- Mar 31, 2014
- 77
This is the first time I have winterized an inboard\outboard and tell me what you think. It is a omc king cobra with a 460....started by changing the oil, oil filter, water/gas filter. Next, I opened the two drain plugs on the block, removed the hoses on the water pump and rubber caps that I am not sure what the part is called, but it is a small cylinder on the back of the engine. Added stabilizer to the gas, pulled the plugs and fogged each cylinder and replaced the plugs. Blew in all the hoses and made sure no water was trapped. After all of this, I pulled the lower unit and inspected the gimble bearing and re greased it. Is it safe to say I will not be cracking any blocks this winter? One question......do I need to do anything to trim tab resovoir and did I miss anything? Thank you.
