breakingbass
- Jul 15, 2014
- 29
hi all, earlier this week i was prepping my boat for a trip this friday and noticed that the tilt was only working intermittently. i went through all the paces of checking the battery which is a month old and is able to power all of the other electronics including the trim, the solenoids/relays which are all clicking and working properly. everything was measured with a multimeter and everything looked proper. i then removed the motor and test it. also running strong and measuring properly.
i then took the cover off the clutch assembly and everything looked proper. i was then able to remove the outer brass gear and worm gear assembly. the hammer blow, worm gear shaft, worm gear itself and the pins all looked perfect and smooth. it did take a little effort to get the gear and the worm gear out so i figured that maybe these two just got jammed.
i cleaned the worm gear and brass gear, reinstalled them, hooked up the motor, and ran it with the cover off, and then ran the motor. the worm gear and brass gear ran like clockwork. once i slipped the clutch pack and shaft in, is where i get the problem. once the clutch pack and shaft are in place, and using my finger in place of the cover to hold it all together, my buddy would run the motor, and it will run in each direction, but only momentarily.
i am guessing that the tensioning bolt on the shaft that presses the clutch pack together is either too tight or not tight enough. any help, info, opinions, or suggestions would be really appreciated. if i left anything out that might help with solving this problem please let me know. the trip i am going on tomorrow is a volunteer event called the purple heart anglers and its mission is to bring disabled veterans on a fishing trip. my buddies and i have volunteered my boat and will be using my boat to take a few vets out and we will be serving as their deckhands. i really dont want to miss it because of my tilt motor. thanks in advance everyone.
