Okay, I got the sterndrive out and made my necessary repair, greased the u-joints, and greased the gimbel bearing. I put on new o-rings (lubricated good with motor oil) and greased the spines on the shaft, being careful not to get grease on front of shaft. I've now been over 2 hours trying to put the drive back - just can't get the splines lines up. Everything came apart fairly easy, so I'm assuming the engine is lined up okay. I am suspending the drive with an engine hoist, so I can adjust the height up and down okay, but I am getting nowhere fast. I'm a newbie working on marine stuff. Any hints or ideas as to what I'm doing wrong?
