Hi all!
You may remember my thread last year about having a pair of these engines that would stay in FMEM
mode and run rough while guzzling fuel. So after fixing the issues, all has been well.
However, after my 14th outing this season, I started noticing something peculiar...(after over 800KM)
The right side engines sometimes cannot WOT. It runs perfect other wise, but
if I WOT it, the left engine will reach 4400RPM but the right one will simply stop
accelerating at a random RPM. Sometimes 3800, sometimes 3200. 2 weeks ago,
I was able to reach 4400RPM with both engines.
However, sometimes the max RPM is below planing speed, 2800 for example.
So I had an Ah-Ha moment: I simply stopped, turned the right engine
off, started it up again and went. Reached planing speed normally and WOT
came up to 3800RPM...
I changed the fuel pump relays in case, but the issue persists...
Any idea what could cause this?
Could it be the coil getting weak?
Could it be the high pressure fuel pump?
I am told the low pressure pump getting weak makes the engines have huge misses, which it does not.
I adjusted my throttle cables and they are still fine.
Did full tune up last year with platinum plugs. Starts on a 1/4 turn.
Any ideas?
Thanks.
MasterGoa
Any ideas?
Thanks.
MasterGoa
