Hi all,
Looking for any suggestion on what to check next. I just bought a 1988 with OMC Cobra 2.3L
Problem:
Engine runs great for first run on the water 10-20 minutes. (should have taken a longer test drive)when throttling down to neutral, gets really rough or stalls. After that, cannot get out of neutral without stalling. similar results on muffs for 20-25 minutes. Temperature is good. Runs really strong when going.
Work done this season:
Carb rebuilt, wires, cap, rotor, cleaned contacts, timing belt appears in good shape.
Any ideas what would cause this after running for a while.
Problem:
