Propeller Shaft broken - repair advice or SEI?
MMWalleyeman
I have a 1990 OMC 3.0L outdrive and the propshaft is broken off after hitting a rock. The shaft still spins in forward and reverse with no other damage visible. How hard is this to fix/replace the propshaft for a DIY 1st timer? Do availability of parts and difficulty cracking it open make a SEI drive the better option? I cant seem to find a lower on craigslist. I appreciate and value your opinions.
jerryjerry05
The changing of the shaft should be done by an experienced mechanic.
The 3.0/ 2.3 Cobra lower unit is smaller than the V-6/ 8.
So if you do find one make sure it's the right size.
Howard Sterndrive
1990 3.0 lower *should* be same physical size as V6 V8. The 13 spline propshaft lowers on the 4 cylinder setups was only 1986-89 I think...
MMWalleyeman
Thanks for your input. So the propshaft splines are the only difference. No big deal since i need a prop too. I may end up going with the SEI but I did find a deal on a full outdrive from a '87 V8 with a prop. I cannot find the chart and I don't have the book. Will this lower fit my 3.0L? Howard , your "should" quote concerns me.
I can then sell the upper since it has the specific gears and useless to me and maybe have a working lower for 100 clams when all is said and done. Thanks in advance!
Idlespeedonly
It will physically fit, But the gear ratio will be way off. And I dont think you will be able to overcome the difference with a different prop.
----------------------------------------------------------------------------------------------------------------------------------------upper------------------- lower
[FONT=Arial,Helvetica,sans-serif]GMC 2.5 Litre[/FONT]
[FONT=Arial,Helvetica,sans-serif]GMC 3 Litre before 1989[/FONT]
[FONT=Arial,Helvetica,sans-serif]21:18[/FONT]​
[FONT=Arial,Helvetica,sans-serif]13:26[/FONT]​
[FONT=Arial,Helvetica,sans-serif]GMC 3 Litre since 1989[/FONT]
[FONT=Arial,Helvetica,sans-serif]21:21[/FONT]​
[FONT=Arial,Helvetica,sans-serif]14:26[/FONT]​
[FONT=Arial,Helvetica,sans-serif]GMC 4.3 Litre[/FONT]
[FONT=Arial,Helvetica,sans-serif]21:19[/FONT]​
[FONT=Arial,Helvetica,sans-serif]GMC 5 Litre[/FONT]
[FONT=Arial,Helvetica,sans-serif]21:17[/FONT]​
[FONT=Arial,Helvetica,sans-serif]GMC 5.7 Litre Cobra / King Cobra before 1988[/FONT]
[FONT=Arial,Helvetica,sans-serif]21:16[/FONT]​
[FONT=Arial,Helvetica,sans-serif]GMC 5.7 Litre Cobra / King Cobra after 1988[/FONT]
[FONT=Arial,Helvetica,sans-serif]24:29[/FONT]​
[FONT=Arial,Helvetica,sans-serif]17:21[/FONT]​
[FONT=Arial,Helvetica,sans-serif]GMC 554 or 502 King Cobra after 1988[/FONT]
[FONT=Arial,Helvetica,sans-serif]17:20[/FONT]​
[FONT=Arial,Helvetica,sans-serif]Ford 2.3 Litre[/FONT]
[FONT=Arial,Helvetica,sans-serif]Ford 351 King Cobra after 1992[/FONT]
[FONT=Arial,Helvetica,sans-serif]Ford 5 Litre or HQ 5 Litre[/FONT]
[FONT=Arial,Helvetica,sans-serif]Ford 5.8 Litre[/FONT]
[FONT=Arial,Helvetica,sans-serif]Ford 7.5 Litre King Cobra before 1988[/FONT]
[FONT=Arial,Helvetica,sans-serif]17:30[/FONT]​
[FONT=Arial,Helvetica,sans-serif]Ford 7.5 Litre King Cobra after 1988[/FONT]
MMWalleyeman
Thanks Idle. That is the chart I am looking for...I looked everywhere! The 1st column is the upper and the 2nd the lower. As I said, I will only use the lower and they have the 14:26 gear set (except the 2.3L and the Kings) so I am good to go. I can put the 5.0L lower on my 3.0L upper.
Thank you all for your help peeps!!!
