Have acquired 1977 starcraft 20' American I/O. Stored in barn since 1999. The out drive was stored in the up position. When engage switch to lower it only hear a thump. What is my next step? Does it have to be lowered in order to see if engine will turn over? Has a 302 ford w/ 2 barrel Holley carb. Wasn't winterized when stored. What should I check? When lowered, can I use plastic barrel filled with water to test? Can't find flush adapter so far. Where can I get a service manual? New to boating and understand that this is a project. Thanks
