WinnerCobra
- Jul 17, 2013
- 29
Alright so i have recently discovered both side of my block just below the exhaust is cracked. the previous owner had used an epoxy/JB weld to fix it. No water in oil seems to just be spraying water. What is the best epoxy or sealant to use to just seal the crack to prevent water from leaving the block? Im aware that it will just keep getting worse im just looking for a temp fix for this year and then will go about the replacing of the block this winter. Any useful hints/suggestions would be awesome.
