kylep123
- May 12, 2014
- 37
I have a the OMC Cobra 4.3l (HO I believe) and it has the holley carburetor with electric choke, I was looking over the engine and noticed I have no Positive wire going to the connector, only the negative is hooked up. Is this an issue that will cause the choke to not disengage? Also if it is possible i would like to hook this up to the battery through a wire with fuse on it, and does this need to be attached to the ignition at all?
