Need some help, I have a 1993 Caravelle 1750 fs that I am changing the motor on. I pulled out a 1992 OMC 3.0l (302CMRAMK) and I have a 1986 OMC 3.0l (302APKWB) to go in it.
Off the bat I noticed the exhaust isn't going to line up with the elbow. I looked at buying the 1986 exhaust pipe but it looks like that pipe will not marry up with the transom plate properly, although it looks like the 1992 transom plate is the same p/n as the 1986 transom plate.
Orginally I planned to rebuild the 1992 motor, but I found the 1986 cheap and decided to scrap the rebuild idea, so I have the entire 1992 motor still in pieces.
Basically, my question is... can I make this work? It looks like I can put the 92 manifold and riser on the 86 block, but will that cause any other problems? Do I need to put the 92 carb on as well? then the 92 fuel pump etc...? does the cycle end?
I appreciate any help or advice, thanks!
