Please help. Last weekend, my Bayliner 88 took on lots of water through the engine compartment due to a loose cap which sits below the air filter. I got the water removed and the cap put back on tightened it. Started the engine with the earmuff connected. It seems the engine is running hot after 5 minutes as water is vaporizing from the cooling system. I could see boiling water and bubbling on the bolts on top of the cooling part where the OMG logo is located. Is this going to be a serious problem with the engine as it may get overheat? Any idea what the problem is? thank you.
Dan
Dan
