Hello all,
I'm going to convert the King Cobra to a crank mounted pump. I have some questions about what I can remove in the way of the old water pump. Obviously I won't run the impeller but can I take out the water pump adapter too? What else can I remove? I even thought about welding up the case of the drive where the old water pump adapter shaft came out.
Here is the schematic -what can I remove? and below is the water pump that I'm installing.
