Re: 1983 OMC 2.5 Coil questions
Thank you for the info, I replaced the points and condenser, but I still was not getting fire from my coil. Test voltage with Prower probe, and it said I only has 4.5 volts on Bat side of coil.
We'll come to find out I pinched the condenser wire in between cap and disturber. Fix that and boat fired right up like always.
Thank you for info.
