Re: 1987 OMC 3.0 jerks or stalls for a split second when cruising at 3000 rpm
Had Carb rebuilt and ran @ lake with same results. Engine is not starving for fuel but problem seems like outdrive wants to jerk and shift out of gear for a split second..Thinking now this could be a problem with ESA or the Dog clutch in lower unit or possible cable adjustment..
I think you should determine the cause before you start replacing systems.
If the engine appears to quit/starve, etc regularly, it could be fuel related. If fuel tank vent line is partially plugged, it will restrict fuel flow and possibly cause what's happening.
Try running the engine on a different fuel source. (portable fuel tank etc) see if it still has the problem. Then work back to the carb through the fuel lines. If you isolate it to the tank, drain and clean the tank, fuel pickup (screen, anti-siphon check valve) then check/replace the filter, fuel pump etc.
If it's ignition related, since there's really nothing wrong with points systems, it could be a poor connection anyplace or a corroded battery connection, ground, etc.
Regards,
Rick[/QUOTE]
