budmanboat
- Feb 12, 2014
- 6
I am new to the forum and need help. I have a 1976 120 HP with OMC outdrive. The tilt motor is located near the bottom of the engine on port side. I can see the 2 wires ( blue/white striped) and green/white striped) located on the motor and the harness that connects them to the respective selenoids. I cannot see where the two bolts/screws connect the tilt motor to the housing. Are these screws flat head, phillips or hex nuts if bolts. I is very tight quarters and may have to use mirror to actually see them. Also, is the motor "grounded" by the through bolts or screws. I do not see a third wire ( black).
The only nomenclature in can see on the motor is SAE J1117 Prestolite. I do not think this motor is attached with a flange.
I have seen several 2 wire motors on line that look identical to what I have and there is a huge price range from $ 59 -$ 239. Please Help if you can.
cadet Budmanboat
cadet Budmanboat
