Hi,
I have a 1995 OMC 5.8l EFI that has some damage where the flapper valve pin sits. There has been a groove worn down the sides and is causing a ticking noise at idle. I know the proper way to repair it would be to replace the y-pipe, but I dont want to pull the engine unless I have too.
I was wonder if there are any fixes to this problem. One idea that i am pondering is locating the mounting holes offset from the original ones and filling the original holes with JB weld.
Any input would be appreciated.
Thank
Thank
