JerryRigged
- Jun 13, 2013
- 24
Hey guys!Need a little help here. I have a 1987 liberator with a OMC 7.5 ford 460 stroked to 514.
Been having trouble this summer with the ignition system.
I have replaced the spark plugs, that didn't fix the problem. They were wet fouled when removed and replaced.
I replaced the cap and rotor, that didn't fix the problem.
I changed the fuel water separator, that didn't fix the problem either.
We took apart the Holley carb and found the power valve was stuck and rebuilt that portion and cleaned it.
It then wouldn't run.
A ford mechanic looked at it and found the points were fused.
I changed them. And now it runs. I had it running on the muffs through the operating temp in the driveway and all went good. However, when I got it out on the water and put it to the metal, the engine pops and sputters intermittently and doesn't reach top RPM or speed.
I'm not sure where i should have the timing set. the engine has been worked. 460 stroked to a 514 with a 4 bolt main and aluminum forged pistons.
currently running aluminum heads and manifold with a holley 750 carb
MSD ajustable ignition with coil
over 93 octane
competition cam
prestolite distributor
platnium plugs
Any ideas??
over 93 octane
competition cam
platnium plugs
Any ideas??
