I have a bad trim sender (P/N 984748 or 18-7634). Sterndrive Model: 302APRMED Serial: T1146823
I also have a Clymer's shop manual. The manual does not specifically say how to do this, but it does have instructions once you have the outdrive apart.
My question is this. How much of the outdrive do I have to disassemble to replace the trim sender?
In the manual, info about the trim sender is shown after:
1) Remove pivot housing
2) Remove gimbal ring
3) Loosen hose clamps
4) Remove bellows and hose
5) Clean or replace sacrificial anode
So it looks like Clymer's gets around to the trim sender in the process of removing the outdrive gimbal housing. They don't cover the sender itself. How much of this work is it possible to bypass?
Thanks
Thanks
