I picked up a 245 four winns and....
Engine 7.5L 460 King Cobra misfires when engine reaches normal operating temp. I already replaced carburetor. Inspected fuel tank. Replaced filters etc. One item I have found is the coil had oil dripping from its internal casing. I replaced with a new coil and it works fine until about 30 minutes of run time than start to miss fire on all cylinders again. When failure occurs I pulled each wire on distributor cap to isolate and found it worsens so it can?t be on any one cylinder. Must be coil again. The coil is warm almost hot. I have seen on other threads here that the resistor wire from the alternator to the coil must be a certain value ohm. I recall reading on a different engine 2 ohms plus or minus .5. Can anyone assist if this could cause my issue of coil heating up and causing a miss fire on all cylinders? I assume this resistor/wire caused a voltage drop and thus reducing the heat of the coil? My other thought to resolve is the esa. Anyone experience an internal failure when heated on the esa thus causing the same problem? Appreciate any help or schematics to resolve issue.
Thank you
Jim
Thank you
Jim
