how to 1989 OMC v8 5.7 inboard engine oil pressure control?
Re: how to 1989 OMC v8 5.7 inboard engine oil pressure control?
thank you
Ayuh,... Welcome Aboard,.... So what's the Problem,..??
Oil pressure is controlled by internal motor clearances, 'n the condition of the oil pump,...
ssashy
The problem is too high oil pressure:
Min turnaround - 4
Max turnaround - 6
How I can controlling it?
Thank you
Min turnaround - 4
Max turnaround - 6
Thank you
Ayuh,... So far, yer makin' absolutely No sense,....
Just What is the above quote supposed to mean,..??
oil pressure is expressed in PSI,....
ssashy
on minimal engine speed oil pressure is 4 PSI, but on maximal engine speed oil pressure is 6 PSI
Redrig
Master Chief Petty Officer
Pressure should be much higher than that, otherwise your engine is toast if it is really that low.
What kind of gauge are you using ? also what is the weight of the oil that is in the engine ?
is the gauge maybe a 40 - 60 psi range ?
ssashy
oppss sorry.. it was kg/cm2
4 kg/cm2 = 56.9 psi
6 kg/cm2 = 85.3 psi
but main quetion is, how I can conrolling the pressure ?
Redrig
what weight oil is in it now ? when you took those readings was the engine cold , or was that after running for a while?
ssashy
can you help find e-book OMC V8 5,7 1986 ?
thank you
ssashy
10w 40 semi syntetic
this reading is all time cold or warm engin
but on second engine is that reading: 2.5 and 4 kg/cm2
Ayuh,... Is this a new to you boat,..??
Has the oil pressure always been at this point,..??
How about some back story, History on the issue,...
Oil pressure is controlled by internal tolerances within the motor, 'n ain't adjustable,...
