Trying to locate a gimbal bearing @ BRP
sam60
I'm going to do a transom mount re-seal and want to replace the gimbal bearing, but since i'm not experienced in it's replacement, I'm not sure what it's called here:
BRP -- Parts Catalogs
I've looked in transom mount and upper gearcase but not sure if it is shown or labeled as something other.
I appreciate any advice and it is not an emergency. ;) I am just looking for a part number.
1992 744DPEAMH
HT32BSX115
Re: Trying to locate a gimbal bearing @ BRP
1992 744DPEAMH
Howdy,
If you look at the "Transom Mount" pictorial you'll see it.
#74
You should also replace the bellows too
#37
37 0913825 BELLOWS, U-joint
74 0983937 BEARING ASSY., U-joint
There are transom service kits I believe that are somewhat generic. It usually includes the bellows, gimbal bearing, gaskets etc...
Don't forget the raw water impeller. I hope you have spares or an engine mounted pump......... I don't think you can buy them anymore.
Regards,
Rick
