Smith & Sons
- Jul 17, 2013
- 2
We have a 1977 Searay 240 Sundancer 351 Ford-OMC.We have converted the mallory points distributor to Pertronix & are not getting 12V to the coil.Can we run a new wire from the ignition switch to the coil,or is there an shift interrupter circut we need to rout through?(allowing an engin stumble to move into gear).Where can I get a wireing diagram of the ignition circut?We were planning on eliminating the ballast resistor,any input on that would be helpfull.Thanks for the help guys!:
