Galaxie1989
- May 3, 2013
- 19
ok, so ive been working on this boat someone gave me. 2.3l (ford) omc cobra. It was parked for 2 years without running. Ive changed the starter, the wiring harness, the ignition switch, plugs,points in distributor, distributor cap, and the coil. The motor is now turning over but im getting a very weak orange spark out of the high tension lead. Any ideas on diagnosing the issue? Im not the most mechanically inclined person so any suggestion would help! Thanks.
Oh and if anyone can tell me the part# i would need to change points to electronic ignition and what coil i could use to eliminate the resistor wire that would be greatly appreciated. I've read conflicting stories about the electronic ignition (some say they dont make them for the 2.3 some say they do but no one says where or what i need to find!)
