I believe I have a switch gone bad on my electric shifter but want to be very sure since a replacement is about $350.00 and will not be returnable. I have hooked a light tester to the pink wire on the ignition switch and jumped to both the green wire of the shift control for forward and the blue wire for reverse as instructed by the manual and have not gotten the tester to light up.
I have also tried to start the engine when I move the switch into a forward and reverse position and not been able to start but have been able to start in neutral as should be the case. My question is could the switch still be bad even though the cutoff works for start up?
