New starter missing terminal "D"
94fwfreedom
Swapping motors mercruiser to omc, and the merc had a new starter, however, it is missing the terminal for the purple wire. How can I bypass this?? The merc HEI did not have a purple wire, but also had a different alternator set up. I am using all omc stuff. Thanks.
gm280
Re: New starter missing terminal "D"
No sure what you are talking about. Post some pictures and a better explanation of your problem so we can help you out... You talk about a starter but then an alternator and an HEI ignition...?
Don S
It's an automotive starter. They don't use that terminal.
attachment.php
gm280
attachment.php
Don, that is why I respect your ideas and comments. You seem to have a vast knowledge of so many issues...
94fwfreedom
Don, the merc had this starter and it worked, and according to the merc diagrams there is no purple wire. But I will go and order the omc starter. Thanks.
