Question regarding CLUTCH PAK REMOVAL in a 1984 Sea Swirl w/ I/O 3.5 OMC
This is my 1st time doing this and there is very little info out there....
I will be replacing the seal due to water in the oil...(see picts)
1. does the out drive need to be supported to remove the outer gear? I know its a good idea from a safety stand point but is it necessary?
2. Once gear is off, is it just a matter of sliding the pack out or does the retainer bearing (outer 3 bolt cover) need to be removed 1st?
Thanks!
Big Dave
Orange County CA.
Thanks!
Big Dave
Orange County CA.
